You must globally enable ICMP Router Discovery.
Change the VRF instance as required. For information about how to use EDM for a non-default VRF, see Select and Launch a VRF Context View.
When you enable ICMP Router Discovery, the port sends Router Discovery advertisement packets.
- In the Device Physical View tab, select a port.
- Select IP.
- Select the Router Discovery tab.
- To enable Router Discovery, select AdvFlag.
- Configure other parameters as required for proper operation.
- Select Apply.
Router Discovery Field Descriptions
Use the data in the following table to use the Router Discovery tab.
Name |
Description |
AdvAddress |
Specifies the destination IP address used for broadcast or multicast router advertisements sent from the interface. The accepted values are the all-systems multicast address 224.0.0.1, or the limited-broadcast address 255.255.255.255. The default value is 255.255.255.255. |
AdvFlag |
Indicates whether (true) or not (false) the address is advertised on the interface. The default value is True (advertise address). |
AdvLifetime |
Specifies the time to live value (TTL) of router advertisements (in seconds) sent from the interface. The range is MaxAdvInterval to 9000 seconds. The default value is 1800 seconds. |
MaxAdvInterval |
Specifies the maximum time (in seconds) that elapses between unsolicited broadcast or multicast router advertisement transmissions from the interface. The range is 4 seconds to 1800 seconds. The default value is 600 seconds. |
MinAdvInterval |
Specifies the minimum time (in seconds) that elapses between unsolicited broadcast or multicast router advertisement transmissions from the interface. The range is 3 seconds to MaxAdvInterval. The default value is 450 seconds. |
PreferenceLevel |
Specifies the preference value (a higher number indicates more preferred) of the address as a default router address relative to other router addresses on the same subnet. The accepted values are –2147483648 to 2147483647. The default value is 0. |
